Re: truma e 3300 problem
Geschrieben von Ingolf aus Berlin am 07. Oktober 2017 09:30:53:
Als Antwort auf: truma e 3300 problem geschrieben von ernesto uhalte am 06. Oktober 2017 22:45:42:
Hello, Ernesto,
I had the same problem a few weeks ago, exactly as you describe it. You can find my repair description as a PDF-file in the LT-Wiki (see left column) under "Truma 2800" (LT-Wiki -> Table of Contents -> Letter ' T'). According to your description, the automatic ignition unit ought to be faulty. Simply replace and it will be fine again (approx. 110€). If your German is not sufficient, I might as well translate the text for you.
Greetings Ingolf
- Re: truma e 3300 problem gr 07.10.2017 10:11 (0)
